CCME 4.1(0) and 7945G
Aug 15th, 2008
IOS version 12.4(15T) supports 7945G.
However, when trying to specify phone type it's not found:
RTR(config)#ephone 2
RTR(config-ephone)#type ?
7902 Cisco IP Phone 7902
7940 Cisco IP Phone 7940
7941 Cisco IP Phone 7941
7941GE Cisco IP Phone 7941GE
7960 Cisco IP Phone 7960
I don't get it. Is there something I did not do? Thanks in advance.
Overall Rating: 4.3 (3 ratings)
Kenneth Mohammed Fri, 08/15/2008 - 13:40
Did you verify that you have the following files on flash:
SCCP45.8-3-2S.loads*
term45.default.loads
term65.default.loads
apps45.8-3-1-22.sbn
cnu45.8-3-1-22.sbn
cvm45sccp.8-3-1-22.sbn
dsp45.8-3-1-22.sbn
jar45sccp.8-3-1-22.sbn
From what i was reading the 7945 should be compatible with cme 4.1. Also try configuring the mac-address of the phone first, and it may populate the phone type by itself. The phone should register if you have the above mentioned firmware in the tftp-server statements in your config.
Hope that helped
ttowle Mon, 08/18/2008 - 13:06
Kenneth,
I have those files, and the phone appears to be registered. The files are specified in tftp to the location in flash. I also have the load specified in "telephony-service":
load 7945 SCCP45.8-3-2S
The phone appears to work okay, but according to the documentation I should be able to specify the phone, but it does not show up in the list.
ttowle Tue, 08/19/2008 - 07:01
There it is. Right in the command reference!
Hmm. Looks like to code is too early for my taste.
Do I really need the keyword command anyway?
ttowle Tue, 08/19/2008 - 08:36
I did not mention the whole reason for this is because I think it may be the cause of the wrong timestamp on the 7945.
rob.huffman Tue, 08/19/2008 - 09:33
Hi Timothy,
I do think that not being able to enter the phone type may be causing the time issue.
Troubleshooting Incorrect Time Stamp on IP Phones in Cisco Unified CME
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_time.html#wp1053981
This was really covered nicely by Paul in this thread :)
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=General&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbf1665/0
Hope this helps!
Rob
