Jaime Valencia Fri, 08/15/2008 - 11:41
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCM? CME? version?
please always include that information when asking for assistance
basic steps would be to create a dial-peer or route patterns to outside world and use a translation pattern or translation rule to change the number to PSTN, pretty easy
java
if this helps, please rate
Jaime Valencia Fri, 08/15/2008 - 11:47
  • Cisco Employee,
  • Hall of Fame,
    2011
k, basic steps would be
decide the number they will dial for operator, if it's going to be 0 then just create a route pattern 0 and send it to the PSTN.
if something else then you can use a translation pattern or the route pattern directly, there is nothing weird on setting this. it's going to be like any other PSTN call
dial , match a route pattern, send it to PSTN
java
