SCE - Collection Manager and Subscriber Manager Upgrade
Aug 15th, 2008
Does anybody know how long the backend systems upgrade takes ? I mean how long it takes for SM and CM from 3.1.5 to 3.1.6 ???
Thanks for info
smahbub Thu, 08/21/2008 - 08:52
To upgrade the CM to Version 3.1.x:
Step 1: Stop the CM
Step 2: Install the new CM using the script.
When upgrading, use the -o option to preserve the existing configuration. The existing scmscm user is used.After the upgrade, when the CM comes up for the first time, the database tables that are new in Version 3.1.x are created automatically.
Note: The upgrade to Version 3.1.x can only be performed from Version 3.x.
grega9999 Sun, 08/24/2008 - 23:35
I did it last week, and it was pretty quick. About 15 minutes for CM and SM. The SCE OS took a little bit longer, about 20 minutes each.
I did have to reload the SM one more time, as it didn't receive logged in users from SCE (Radius Sniffer LEG).
