anyconnect SSL VPN
Aug 15th, 2008
Hi All,
I have a strange problem with ssl vpn in IOS, I can bring up the ssl vpn web page from one pc and login, but from another pc, when I try to connect to web page, browser can't find the web page. both PCs are using IE version 7.0.
any suggestion would be very appreciated.
Farrukh Haroon Sat, 08/16/2008 - 23:16
Just double check the browser,proxy settings etc. In Internet Options >> Advanced >> Check the SSL/TLS settings. (All versions).
Add SSL webpage to list of trusted sites. Then check. Also try to telnet to the SSL port and see if you get any response (or the connection is refused).
