Calls with Caller ID "0" can't get connected
Aug 15th, 2008
The user states that he can't talk and hear anything on incoming calls with caller ID "0". These calls get disconnected after 50-60 seconds automatically.
Does anyone know what's going on?
Overall Rating: 4 (1 ratings)
mhering8650 Fri, 08/15/2008 - 12:37
How are the calls coming in? SIP/PRI/POTS? Is this a CCM or CME? What Version?
Are U translating on the way in etc?
learnerkang Sun, 08/17/2008 - 10:18
We have PRI connections with AT&T and we are using CCM V4.2.
As for translation,I'll check it later.
Thanks.
Marwan ALshawi Sun, 08/17/2008 - 19:42
if u r using H323 gateway we can block this call but if u use mgcp not possible to match it based on calling number !!
just give us what are u useing and what countermeasure u wanna take..?
Marwan ALshawi Sun, 08/17/2008 - 20:49
if u wanna block this call
do the following
voice translation-rule 1
rule 1 reject /^0$/
voice translation profile call_block
translate calling 1
now go to the dial-peer that point to ur PSTN T1 E1 ISDN what ever and apply it in the inbound direction
for example
dial-peer voice 9 pots
translation-profile incoming call_block
or apply it liek:
call-block translation-profile incoming call_block
this way any call comes to ur gateway with calling number "0" only will be blocked
good luck
please, if helpful rate
learnerkang Mon, 08/18/2008 - 10:12
I wonder if you could tell me why those calles can't get connected. The phone is able to ring but user cound't talk and hear.
Is something regarding to Gateway or CCM's settings?
Thanks.
