FXS Polycom: Conf acting as a Transfer
Aug 15th, 2008
I've got a CUCM 6.1 server using a Cisco 2821 router as an MGCP gateway. The router has a number of FXS ports. When an analog polycom device is connected to one of these ports is can make calls with out a problem.
When you press the conference button this happens:
1. Current call(Call A) placed on hold.
2. Polycom gets dial tone.
3. Number dialed, rings. (Call B)
4. Caller B answers, call is good.
5. Conf button pressed to join all parties.
6. Polycom drops out of call, Call A and Call B are still connected.
This is happening on mulitple ports and polycom devices, so I've ruled out hardware as a problem. Does anyone have any ideas on this one? Thanks!
espereir Fri, 08/15/2008 - 13:19
  • Silver, 250 points or more
Hello Gregory,
I am afraif that this is working as design. Support for conferencing on analog FXS is limited to gateways configured for SCCP (see the following for more info), but hookflash can only initiate transfer when the gateway is configured for MGCP:
http://www.cisco.com/en/US/tech/tk1077technologies_configuration_example09186a00801f3b42.shtml
When a gateway is configured for SCCP, you can initiate conferences and other supplementary services:
http://www.cisco.com/univercd/cc/tddoc/product/software/ios124/124newft/124t/124t2ht1vg224.htm
Hope this helps!
gmgarrian Sat, 08/16/2008 - 15:13
Makes sense to me. Both those links lead me to "not found" sites. Do have any others?
Rob Huffman Sun, 08/17/2008 - 09:28
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Gregory,
I'll try to fill in for my friend Esteban for a minute here :)
Configuring SCCP Controlled Analog (FXS) Ports with Supplementary Features in Cisco IOS Gateways
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxssccpsplmft.html#wp1101486
Hope this helps!
Rob
gmgarrian Mon, 08/18/2008 - 11:42
Thanks for the info. I'll give it a try once I read through and understand it all.
espereir Mon, 08/18/2008 - 12:32
You are welcome and please let us know how it goes!
gmgarrian Fri, 08/22/2008 - 09:36
Okay, if I understand everything correctly, this won't work if the rotuer is configured via MGCP. I'll have to reconfigure it as a SIP gateway (like the CUBE config) and set a dial peer for those FXS ports with the hookflash config on it?
