vlan question
Answered Question
Aug 15th, 2008
Greetings,
Is it possible to setup 8 separate vlans with the following firewall? Is there an additional license or upgrade needed to allow vlan support for all the ports?
ASA 5505 50-User Bundle includes 8-port Fast Ethernet switch, 10 IPSec VPN peers, 2 SSL VPN peers, 3DES/AES license and 1 expansion slot
Mfg. Part No. ASA5505-50-BUN-K9
Alberto
Correct Answer by JORGE RODRIGUEZ about 8 years 5 months ago
Alberto,
You need security plust license ASA5505-SEC-PL in order to create that amount of VLANs in ASA5505, you'll have up to 20 VLANS max.
License specs
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/prod_brochure0900aecd80402e36.html
See ASA5505 Model/License details
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Rgds
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Fri, 08/15/2008 - 12:31
Alberto,
License specs
Rgds
Jorge
albertom Fri, 08/15/2008 - 12:59
Jorge,
Thank you for the quick response and helpful information.
Alberto
