Per Floor Vlan / DHCP
Aug 15th, 2008
I've been reading about per floor vlan's and I want to do that. My question is when I use Vlan 100 for the first floor and vlan 200 on the second floor in a different subnet I guess I need a seperate DHCP pool for each subnet?
Donnie
Overall Rating: 5 (2 ratings)
JORGE RODRIGUEZ Fri, 08/15/2008 - 12:56
  • Green, 3000 points or more
Donnie, you have the correct idea, if you create VLAN100 for the switch say in floor-1 you create SVI in tour code switch, assume VLAN100 for floor-1 is 10.10.10.0/24 then you would need a DHCP pool for that subnet and configure ip-helper address in SVI interface for vlan100, repeat the process for VLAN200 etc..
Rgds
Jorge
Giuseppe Larosa Fri, 08/15/2008 - 12:57
  • Hall of Fame,
    Founding Member
Hello Donnie,
your understanding is correct you need a separate DHCP scope/pool for each IP subnet/Vlan.
We do so and it works well at some remote sites.
If using an external DHCP you will need ip helper-address x.x.x.x under each SVI L3 Vlan configuration instead of defining the DHCP pool.
Hope to help
Giuseppe
HoustonG33K Fri, 08/15/2008 - 13:07
Thank you both! Thats what I thought. I work for an engineering firm that uses huge CAD drawings and the network has been limping bad. I thought by per floor vlans i could speed things up a little bit.
Thanks again!
Donnie
