Guest access to WLAN.
Answered Question
Aug 15th, 2008
I have 8 Cisco 1230AP's providing access to my LAN for laptop users. The encryption is via WPA. I now need to setup unencrypted access to the internet for guests/visitors - keeping them away from my LAN and internal network. How can I do this? Thanks for your help...
Correct Answer by Scott Fella about 8 years 5 months ago
the only thing you can really do if your ap's are autonomous is to create another ssid and place that on a different vlan. Then you can use acl's to prevent guest subnet from accessing the internal network. Or you can place the guest user on that different vlan and then have a dsl connected to that subnet for guest users to use. That vlan will not have a layer 3 interface so it will be isolated from the rest of your network.
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Fri, 08/15/2008 - 18:24
