Change PIN on IP Phone
Aug 15th, 2008
Hello
I need a help
I have an environment with Callmanager 5 with extension mobility and users will not have access to a computer to change the password used to log the PIN Extension mobility.
Can place a link or something that the user himself through the phone change your password, the PIN
Jaime Valencia Fri, 08/15/2008 - 16:49
  • Cisco Employee,
  • Hall of Fame,
    2011
you would need to develop a whole new service using jsp or asp to do that, there is no built-in way to do it. easy way would be to have the administrator set the PIN and give it to users, or seek a way to give them access to a pc just to do that one time only
java
if this helps, please rate
