08-15-2008 05:25 PM - edited 03-10-2019 04:01 PM
hi, while upgrading to ACS version 4.1.1.24 from 3.3.4. during installation, if i am retaining the existing configuration.
will there be any issue in the services and certificate that worked fine in 3.3.4 with newer version 4.1.1.24?
thanks
08-21-2008 06:05 AM
You can use the ACS upgrade mechanism to upgrade from ACS SE 3.3.3, 3.3.4, 4.0.1 to ACS SE 4.1.1.24. This section describes the procedure for performing a full upgrade from ACS SE 3.3.3 to ACS SE 4.1. using the upgrade package mechanism.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.2/installation/guide/solution_engine
Log in to Community
