Cisco VPN doesn't work with iPod Touch/iPhone
I set up my company's VPN network on a PIX506E firewall. but when i tried to connect to the vpn from my ipod touch, it failed. it uses IPSec over UDP. does ipod touch/ipohone only work with IPSec over TCP? If so, what differently i need to do to setup my pix506E to use IPSec over TCP instead?
Tharaka
ggilbert Mon, 08/18/2008 - 09:18
Hello Tharaka,
The Apple iPhone/iTouch only works with IPSec over NAT-T if it is connecting through a NAT device or just IPSec. Its the client side limitation.
So, you might want to enable IPSec over NAT-T on your PIX 506E to support iPhone/iTouch IPSec connections.
Command Usage:
isakmp nat-traversal [natkeepalive]
You can enter a keepalive value of 20. (Its in seconds.
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/gl.html#wp1027312
Please rate this post if it helps.
Gilbert
