ipcc 5 seats
Aug 15th, 2008
hi
i got the ipcc 5 seats that came with ccm 6.x, and i want to install this ipcc, my question is that do i need to install this ipcc on an MCS server or any pc will work?
another thing, should i get Win2K server from Cisco or if i have my own Win2K i can use it, in this case how to make this Win2k ready for the ipcc installation?
Jaime Valencia Sat, 08/16/2008 - 06:35
  • Cisco Employee,
  • Hall of Fame,
    2011
you need an MCS server and the CIPT OS from Cisco
java
if this helps, please rate
Chad Stachowicz Sat, 08/16/2008 - 16:27
  • Silver, 250 points or more
java thats a good question I want to ask. Is CIPT OS 2003 a purchase from cisco, why doesnt it come with the uccx copy that comes with ccm. seems unsensible to me ;)
Chad
Jaime Valencia Sun, 08/17/2008 - 09:45
  • Cisco Employee,
  • Hall of Fame,
    2011
i really don't know why the OS is not bundled with the CUCM, but if you already have any CIPT OS 2000 or 2003 that you used in a CCM 4.X version, you can use it as well for the UCCX that you receive
we would need to ask a marketing guy to find out the answer to that =)
java
