ssh - Cisco 4500
Amin Shaikh
How to configure SSH for Cisco Catalyst 4500
can I get step by step guide
10 Replies 10
Tarun Lohumi
You would not really find the SSH configuration guide for a specific product.
Here is the configuration guide for SSH on Cisco IOS:
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml
Hope that helps!!
During configuration of SSH on 4500 will it impact any connected Servers or VLANS.
I mean anyone will get disconnect.
Its a production BOX.
Amin
Just enabling SSH on the 4500 would not impact any connected server or VLANs. If you start to change access privileges (to require SSH and not telnet, etc) then there is possibility of affecting other devices.
Rick
Rick
We have two cisco catalyst 4500 L3 switch (cat4500e) and running version 15.2(2)E5a.
We are not able to configure ssh on this switch, ssh commands not supported and transport input ssh command also not working.
Any way is there for ssh on 4500e and why command is not working.
which ios do you use ? Please give full name :-)
IOS- cat4500e-ipbase-mz.152-2.E5a.bin
ssh command is not working in this IOS...
if you know the way to configure ssh on 4500e please tell me
I am also working on the same but till I don't get any solution
You need an image with k9 in its name, for example cat4500e-ipbasek9-mz.152-2.E5a.bin.
Yes your right need image with k9.... thak you very much Evgeniy
Sudhir,
check this command
line vty 0 4
exec-timeout 60 0
password 7 <>
transport input ssh
** please rate if helpful**
ericngimme
line vty 0 4
password password
login (depending on what code)
transport input ssh
