ACL's
Aug 16th, 2008
Hi Experts,
Jus small query about ACL last field.
#access-list <acl id> permit/deny source-adds wild-mask desti-adds wild-mask operator eq
Can anybody tell what is the last field 'eq'
If above syntax (command) wrong also
Naidu.
Tarun Lohumi Sat, 08/16/2008 - 03:47
  • Cisco Employee,
Hi Naidu,
The 'eq' field in the end in used to identify a particular port number under a protocol. For example to identify only the 'telnet' protocol under TCP we can use the following statement
access-list 101 permit tcp host 10.1.1.2 host 172.16.1.1 eq telnet
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml
Hope this helps!!
