CER doesn't see SNMP on CUCM
Aug 16th, 2008
Anyone seen this one? I have a TAC case pending on it...
CER is Version 2.0.3
CCM is version 6.1(1)
Problem is
CER is refusing to communicate via SNMP with the CUCM. CUCM communities have been checked and rechecked, they have also been tested with a 3rd party SNMP tool (GETIF) to make sure they do respond. Boxes can ping each other. CER does register it's route points.
Syslog error message thrown when the phone update processes is
08-16-2008 17:28:45 Local7.Debug 10.15.1.30 %CER_CER_AGGREGATOR-6-INFO:Device 10.15.1.10 is SNMP unreachable. Please check SNMP settings in CER and also on this CCM. Please confim proper access previlage ( READ_ONLY ) set on this box for SNMP service. Also, verify n/w connectivity.
The result is that CER isn't learning about any of the phones in the CUCM.
We have tried
removing CUCM from CER and put back
retype/recheck all SNMP community strings
reboot all involved servers
Overall Rating: 3.8 (5 ratings)
Chad Stachowicz Sat, 08/16/2008 - 16:26
  • Silver, 250 points or more
Just to make sure you have the SNMP on all CCM's turned on. Also when you added the SNMP string, you restarted the SNMP Master service? I see you rebooted the boxes so this would assure this. Also the SNMP strings you added are allow anyone except those listed correct? The other checkbox would deny all under the community string setting!
HTH,
Chad
justincohen Sat, 08/16/2008 - 16:46
Chad;
You pretty much nailed it there. The error message is a little misleading it claims the server is not reachable -- that's not correct, as GETIF reports the SNMP is clearly working.
CUCM was showing SNMP not being activated - so activating that seemed to fix the problem.
There were many CER documentation errors related to the CUCM setup for 6.1, so in the TAC case I outlined them and the TAC engineer is sending them to the Doc guys to have the documentation fixed.
Chad Stachowicz Sat, 08/16/2008 - 17:08
Your welcome, next time it actually solves your problem, you should probably try rating it a 5, since indeed it did solve it prior to TAC.
Cheers,
Chad
evan.proios Wed, 09/23/2009 - 09:52
I have a similar issue but with CCM 4.1 and CER7 everything works except I cannot see the extentions in CER I get the error "Device {CCM} is SNMP unreachable. Please check SNMP settings in CER and also on this CCM. Please confim proper access previlage ( READ_ONLY ) set on this box for SNMP service. Also, verify n/w connectivity."
The settings in CER are correct, where do I check on CCM 4.1 (3) ???
