dot1q trunk
Aug 16th, 2008
hi everybody!
Does dot1q not support pvst?
cisco switches by default operates in pvst mode. So how can dotq trunk appears to support pvst?
thanks a lot!
lamav Sat, 08/16/2008 - 15:36
dot1q is perfectly compatible with pvst STP standard.
Not sure I understand what you're asking...
sarahr202 Sat, 08/16/2008 - 18:03
thanks for your reply. I just found out it was pvst+ not pvst that support switches by default operate pvst+ so that explain why dot1q tunnel works between switches.
