CallManager 4.2 Integration with Unity 7
Peter Valdes
Level 3
Level 3
Just need some links regarding CallManager 4.2 Integration with the new Unity 7.
We are currently running Unity 4.0(5) Messaging, OS WIN2K, Exchange 2K, SQL 2K on box which is also integrated with our standard CallManager 4.2. I would like to know if the upgrade from Unity 4.0 to Unity 7 is possible using the same current setup.
BTW, our current Unity server are using HP DL380 G5 platform with average of 32 VM ports.
If this is not supported, we have an alternate option to upgrade all our clusters to Unity 5.
Rob Huffman
Hi Peter,
Here are some links to get you started;
Supported Version Combinations for Cisco Unity, the Cisco Unity-CM TSP, and Cisco Unified Communications Manager
Cisco Unity 7.0(2)
Cisco Unified Communications Manager 6.1(x), 6.0(x), 5.1(x), 5.0(x), 4.3(x), 4.2(x), 4.1(3), 4.1(2), 3.3(x)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cutspmtx.html
Documentation Guide for Cisco Unity Release 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/roadmap/7xcudg.html
System Requirements for Cisco Unity Release 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/requirements/7xcusysreq.html
Cisco Unity Supported Platforms List
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd802132ef.pdf
Cisco Unity 7.0 for Microsoft Exchange
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/data_sheet_c78-478111.html
There are six versions of the Cisco Unity installation guide, each containing instructions for a specific configuration. Use the list below to confirm that you are using the correct version of the guide for the Cisco Unity version 7.x configuration that you are installing.
For Release 7.x, the Cisco Unity installation guide was not updated. The URLs listed in this document are to Release 5.x versions of the installation guide. All 5.x content applies to Release 7.x. Information on new and changed features in 7.x-including any required procedures-can be found in 7.x release notes
(http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_release_notes_list.html).
Use the Installation Guide That Matches the Cisco Unity 7.x Configuration
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/correct_ig/7xcuigcrct.html
Hope this helps!
Rob
Rob Huffman
Hi Peter,
Cisco Unity 7.0(2)
Hope this helps!
Rob
Hi Rob,
Many thanks for your reply. This has help me big time.
Peter
Hi Peter,
You are most welcome my friend :) Glad to be of some small help here.
Take care,
Rob
kraven0929
How did this integration work for you? We are using ccm 4.1.3 and going to unity 7. We are having issues getting the voice ports on callmager to register correctly. They come up as unknown. I was thinking it might be TSP issue. any thoughts? insight?
