SSH to ASA using Hostname
Aug 16th, 2008
I would like to use a host name associated with the enabling of SSH on the outside interface of an ASA5505. The command syntax makes you think it is possible:
xxxxxx-fw1(config)# ssh ?
configure mode commands/options:
Hostname or A.B.C.D The IP address of the host and/or network authorized to
login to the system
The firewall can both resolve and ping the name that I want to use, but when I enter the 'ssh <chosen host name>', I get an error message. Is there some other command needed, or am I missing something here?
Farrukh Haroon Sat, 08/16/2008 - 23:06
You can add the hostname first using the 'name' command and then put it in the SSH command. To make the configuration more 'readable'.
dasmith Sun, 08/17/2008 - 05:09
Thanks for the reply. I had thought of that approach, but my intent is to provide support to a 5505 via my home broadband connection which can periodically change IP address. I have dynamic dns set up here at home, so I thought that the 'ssh hostname' would work to support that scenario.
Tshi M Sun, 08/17/2008 - 15:48
You mentioned that you get an "error message". What is the error message? You might have to register your outside address as well so it can be reached via Internet.
