dot1q and pvst+ region
Aug 16th, 2008
hi everybody!
let say we have 3 switches with 4 vlans, running pvst+. switches have to connected by dot1q trunk only.
I read somewhere dot1q requires cst so how we connect switches running pvst+ by dot1q trunk?
thanks a lot!
andrew.prince@m... Sun, 08/17/2008 - 04:25
Sarah,
802.1q does not support PVST+ natively, however Cisco switches do support PVST+ over 802.1q trunks. So with "all" cisco switches and PVST+ (which is the default) everything will be ok.
When you use cisco switches with non-cisco switches, you must use a 802.1Q trunk, that will support CST (Common Spanning Tree), with 802.1Q into a CST region, only one instance of STP runs over the native VLAN, and one STP topology is used for all VLAN's.
HTH>
