6509 ios upgrade failed
Aug 16th, 2008
I have a case open with tac, but if anyone has an idea why my ios upgrade failed, I would be most grateful. Original config booted from sup-bootflash:, I moved the IOS to disk0: and updated config to boot systemd dis0:filename.
Now 6509 comes up to router>
Its acting like nvram is empty, there is no start config. Any ideas?
DARYLE DIANIS Sun, 08/17/2008 - 03:25
thanks, problem solved already, but the reg was 0x2102. seemed to be related to the ios version, it blew away my config and that was just the start of it....
