ASA context1 with failover showing 99% memory used
Aug 16th, 2008
  • Silver, 250 points or more
One of my ASA is running multiple context (2) and failover "active/standby". One of the context is showing 99% memory used. How do I clear up of free up the memory?
Tshi M Sun, 08/17/2008 - 07:24
Hi Farrukh,
I thought of rebooting but the reload option is not available. I would have to physically reboot the unit since it is at remote location.
Farrukh Haroon Sun, 08/17/2008 - 08:25
  • Red, 2250 points or more
Try to pin down the process that is utilizing most resources. Clear the xlate and arp tables.
In fact do a 'clear local-host all'
'clear xlate' 'clear arp' and see if it gets any better.
Farrukh
Tshi M Sun, 08/17/2008 - 09:10
Both commands did not help. I went to the remote site and I physically rebooted the firewall but context (ctx) still showing 100% of memory used while context (admin) is showing 0%.
FEZ/admin# sh memory
Used memory: 2539120 bytes ( 0%)
Total memory: 536870912 bytes (100%)
FEZ/admin# sh failover
Failover On
Last Failover at: 12:56:07 EST Aug 17 2008
This context: Active
Active time: 113 (sec)
Interface inside (192.168.0.36): Normal
Interface outside (172.16.0.4): Normal
Peer context: Standby Ready
Active time: 161 (sec)
Interface inside (192.168.0.37): Normal
Interface outside (172.16.0.5): Normal
FEZ/ctx1# sh failover
Failover On
Last Failover at: 18:06:51 EST Sep 13 2006
Active time: 60814593 (sec)
Interface inside (192.168.0.52): Normal
Interface outside (172.16.0.20): Normal
Active time: 0 (sec)
Interface inside (192.168.0.53): Normal
Interface outside (172.16.0.21): Normal
Stateful Failover Logical Update Statistics
Status: Configured.
Stateful Obj xmit xerr rcv rerr
RPC services 0 0 0 0
TCP conn 157373730 0 128 0
UDP conn 140620519 0 181 0
ARP tbl 25391 0 4 0
Xlate_Timeout 0 0 0 0
FEZ/ctx1# sh mem
Used memory: 537200184 bytes (100%)
