CDR String / Information
Aug 16th, 2008
Customer is having Opera Software to manage their hotel management system. They are looking for IP Telephony solution (UC 500 0r Cisco Call manager express 4.3 )
Opera is having call billing feature. They want to generate bill through their Opera software. For that, we need to send CDR information/string to this application. Please suggest me whether its possible or not .
If yes how to do it?
Jaime Valencia Sun, 08/17/2008 - 09:53
this has already been asked before:
IP Telephony: CME Billing
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cc1714e/0#selected_message
you may also use the search function within NetPro to look at previous answers
java
if this helps, please rate
manojdubey02 Sun, 08/17/2008 - 22:39
Thankx for your reply... i m not getting clear idea about on above problem based on your earlier discussion.
I want to know whether CME will send the CDR information/String to Opera application. Becouse these string will be used to generate the billing through Opera software.
If it will work as above so I can pitch the solution to our customer
Manoj
