Marwan ALshawi Sun, 08/17/2008 - 04:15
try to copy an existing softkey template..
then change it then aplly it to the phone
Rob Huffman Sun, 08/17/2008 - 04:48
Hi Sandeep,
Sadly, as you nicely noted, the "New Call" Softkey is a mandatory Softkey (note the ** beside it in the selection box) and therefore cannot be removed. It can however be moved down the Selection List Order so it is not on the first line. The other thing of note is that as soon as you go over 4 Softkeys in any Template the "More" softkey becomes mandatory as well :(
Hope this helps!
Rob
