IPSec newbe question
Aug 17th, 2008
I am trying to connect two routes using IPSec but having some trouble as this is my first time. can someone help why there is this 'incomplete' in between the commands? and the tunnel does not seeem to be working.
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
crypto isakmp key cisco address 192.168.3.2
no crypto isakmp ccm
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map mymap 10 ipsec-isakmp
! Incomplete
set peer 192.168.3.2
set transform-set myset
match address acl_vpn
ARANA
Overall Rating: 4 (1 ratings)
Marwan ALshawi Sun, 08/17/2008 - 05:01
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
try to change the crypto isakmp to the following
crypto isakmp key cisco address 192.168.3.2 255.255.255.255
then
group 2
crypto isakmp enable
i know those not directly related to ur problem but they need to be done anyway
good luck
husycisco Sun, 08/17/2008 - 05:32
  • Gold, 750 points or more
Hello Arana,
Whenever you see an "! Incomplete
" in crypto map, that means it is incomplete somehow. Double-check the spelling of acl_vpn in original ACL and in crypto map statement. If you are sure that all fine, then remove the "crypto map mymap 10" entry and write again.
You should not see "! Incomplete " there
rana_beech Sun, 08/17/2008 - 07:07
Hi Husy,
Thanks. I did make some type on the access list. So now I have made the changes and I do not see the incomplete message displaced. I am making progress .... does this mean that my IPSec is working
R4#sho crypto isakmp sa
dst src state conn-id slot status
192.168.1.2 192.168.3.2 MM_NO_STATE 0 0 ACTIVE (deleted)
192.168.3.2 192.168.1.1 MM_NO_STATE 0 0 ACTIVE (deleted)
Could I also check if this access list covers interesting traffic? source is from net 192.168.4.0 to any destination. Is a specific destination required or will any be ok to use.
ip access-list extended acl-vpn
permit ip 192.168.4.0 0.0.0.255 any
ARANA
husycisco Sun, 08/17/2008 - 07:33
Hello Arana,
To say that your IPSEC VPN is working, QM_IDLE is the state that you should be seeing, not MM_NO_STATE,
If you specify destination as "any" than your all traffic including internet will travel over the tunnel. Dont use any statement unless you know what you are doing.
Please post your running config and write exactly what you want to achieve, then let us make suggestions.
rana_beech Sun, 08/17/2008 - 14:53
Hi Husy,
I want all internet traffic to go through our central site. Does it even work if I do not specify any statement? I was not aware of that. Here is the running config.
encr 3des
hash md5
group 2
crypto isakmp key cisco address 192.168.1.2
set peer 192.168.1.2
match address acl-vpn
interface Serial1/0
no ip address
encapsulation frame-relay
serial restart-delay 0
no dce-terminal-timing-enable
no frame-relay inverse-arp
crypto map mymap
interface Serial1/0.1 point-to-point
ip address 192.168.3.2 255.255.255.0
frame-relay interface-dlci 401
crypto map mymap
interface Serial1/1
ip address 192.168.5.1 255.255.255.0
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.3.1
permit ip 192.168.5.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
ARANA
