AIM-CUE 512MB or 1G
kdunning
I am trying to verify the capacity of the AIM-CUE module and none of the commands we have tried has given the modules capacity w.r.t. whether it is a 512M or 1G module.
Output so far:
cue> show memory
SDRAM (MByte): 256
Total Memory (kB): 255332
Active Memory (kB): 13040
Inactive Memory (kB): 201904
Other Memory (kB): 20060
MemoryPool (kB): 20328
Kernel Memory
TOTAL INUSE MAXUSED ERR TYPE
5528 4949 4969 0 fs
7500 6633 7420 0 other
148 91 113 0 net
cue> show hardware
CPU Model: Celeron (Coppermine)
CPU Speed (MHz): 298.895
CPU Cache (KByte): 128
Chassis Type: C2811
Chassis Serial: FHK1106F1MQ
Module Type: AIM
Module Serial: FOC12032LWC
SDRAM (MByte): 256
Marwan ALshawi
do the following command
CUE#show voicemail limits
Default Mailbox Size (seconds): 420
Default Caller Message Size (seconds): 60
Maximum Recording Size (seconds): 900
Default Message Age (days): 30
System Capacity (minutes): 480
Default Prompt Language: en_US
Operator Telephone: 0
if u look at the line
this is the system capacity in minutes
if AIM-CUE (512 MB) Hours of storage 8
if AIM-CUE (1 GB) Hours of storage 14
so upon the above example we do divide the number of minutes on 60 to make it in houres
480/60 = 8
then it is AIM-CUE (512 MB) easy trick :)
good luck
please, if helpful rate
