Etherchannel bandwidth ?
ciscosom
We have configured Etherchannel to bind 3 Fiber ports that are trunked btw 6509 & 4507. I can see all the three ports part of the Etherchannel/portchannel. But my concern is when i check output for: -
"Sh int portchannel 1" , i noticed the speed shows 1000\Mbps , i was expecting it to be 3000\Mbps . Can you experts throw some light on this ?
Som
Marwan ALshawi
if u consider the port channel applied to all three ports then
1000 + 1000 + 1000 = ? right :)
if helpful rate
good luck
Thanks for your response Marwanshawi , Can you let me know what else needs to be done apart from the below configuration to get 3GB Speed in "SH ports -channel output "?
interface Port-channel1
switchport
switchport mode trunk
no ip address
interface GigabitEthernet7/1
switchport
no ip address
channel-group 1 mode on
interface GigabitEthernet7/2
switchport
no ip address
interface GigabitEthernet7/3
switchport
no ip address
interface GigabitEthernet7/4
switchport
no ip address
interface GigabitEthernet7/5
switchport
no ip address
interface GigabitEthernet7/6
switchport
no ip address
interface GigabitEthernet7/7
switchport
no ip address
interface GigabitEthernet7/8
switchport
no ip address
Atl-Core#sh int port-channel 1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 001c.5824.ace0 (bia 001c.5824.ace0)
MTU 1500 bytes, BW 3000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is on
Members in this channel: Gi7/1 Gi7/2 Gi7/3
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 126000 bits/sec, 70 packets/sec
20046 packets input, 3364492 bytes, 0 no buffer
have u seen the line in us show command
this is bandwidth " BW 3000000 Kbit "
is that what u look for ?!
Oops ,, I was thinking the speed would increase (silly me ) , thank you so much for setting me straight . Appreciate your help
