call manager connect ccme
Answered Question
Aug 17th, 2008
Hi everyone:
I make a experiment to simulate call manager and ccme on one pc, below is the sketch map:
ccm ----R1----R2------IP communicator 2(4803)
| (gateway) (CCME)
IP communicator 1 (4604)
Now IP communicator 1 can call IP communicator 2(4604---->4803) ,but 4803 cannot dial 4604, My ccm version is 5.0.1,ccme version is telephone-service 3.3 , R1 is the gateway of ccm , R2 is the ccme that ip2 register to it ,below is two router's show run , who can tell me what can I do ?
R1 show run:
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface FastEthernet0/0
ip address 5.x.x.x.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
ip address 172.18.1.254 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.18.1.254
ip http server
no ip http secure-server
ip forward-protocol nd
ip route 172.17.1.0 255.255.255.0 5.0.0.2
control-plane
sccp local FastEthernet1/0
sccp
sccp ccm 172.18.1.1 priority 1
dial-peer voice 2000 voip
destination-pattern 46..
session target ipv4:172.18.1.1
dial-peer voice 10 voip
destination-pattern 48..
session target ipv4:172.17.1.1
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
end
R2 show run:
version 12.4
service config
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip address 5.0.0.2 255.255.255.0
duplex auto
speed auto
ip address 172.17.1.1 255.255.255.0
duplex auto
speed auto
ip http server
ip route 172.18.1.0 255.255.255.0 5.0.0.1
control-plane
session protocol sipv2
dial-peer voice 20 voip
telephony-service
max-ephones 2
max-dn 2
ip source-address 172.17.1.1 port 2000
auto assign 1 to 2
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 4 gain -6
transfer-system full-consult
ephone-dn 1 dual-line
number 4803
ephone-dn 2 dual-line
number 4804
ephone 1
mac-address 000C.2900.E613
type CIPC
button 1:1
ephone 2
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
end
Correct Answer by Marwan ALshawi about 8 years 5 months ago
first
u dont need dial-peer voice 10 voip on router 2
on both routers add the following
voice service voip
allow connection h323 to h323
then
make sure that the h323 gateway defind corectly on the CCM for example make sure is has enogh rights to call the ip comunicator 1
through partitions and CSS
if u use them
also i would suggest u to replace the following.. because u have PROBLEM with the DESTINATION IPs
replace:
to
session target ipv4:5.0.0.1
and also:
session target ipv4:5.0.0.2
i mean change the distination IPs
good luck
please if helpful Rate
Overall Rating: 4 (1 ratings)
Correct Answer
Marwan ALshawi Sun, 08/17/2008 - 21:55
first
voice service voip
then
if u use them
replace:
to
and also:
good luck
3dtgnt_ljm Sun, 08/17/2008 - 22:50
haha! You are great ! you resolve my problem !thank you very much!! Now I can dial from A to B and from B to A!
Marwan ALshawi Sun, 08/17/2008 - 23:42
u welcome!!!
but thorugh ur rating i though not solved completly:)
anyway good luck
