ASA 5520 virtual firewalls & SSL VPN
Aug 17th, 2008
We are going to install two ASA 5520 boxes with HA ( Active-Active or Active-Passive )
The boxes include 50 context licenses(virtual Firewalls) and SSL VPN licenses 750 Nos. each.
IS it impossible to use VPNs and contexts licenses with HA?
dhananjoy chowdhury Sun, 08/17/2008 - 22:45
If you are configuring the ASA firewalls in Multi context mode , then you cannot use the features like VPN, dynamic routing,etc.
If you go for Active/Active HA, you must have multiple contexts and so IPSec or SSL VPN cannot be enabled.
Farrukh Haroon Mon, 08/18/2008 - 11:17
Well its obviously not 'same', Active Active lets you load share the traffic across the two firewalls, which is a better use of resources. However sometimes it makes it pretty difficult to troubleshoot network problems. If your primary WAN/internet link satisfies your needs you can go with Active/Passive. The same would also be true for the ASA throughput. If the throughput of one firewall suffices, you can go for Active/Passive. However to run VPNs this is your only choice on the Cisco Platform.
kosalasuranjith Mon, 08/18/2008 - 19:13
I mean that if we configure two ASAs as Active/ Passive mode, Can't we still use virtual firewalls, and VPNs??
Farrukh Haroon Mon, 08/18/2008 - 21:20
In Active/Passive mode you can use VPNs. However to run virtual firewalls you have to go into 'mode multiple'. As soon as you do that, you have say bye-bye to VPNs,Dynamic routing and some other features.
azore2007 Tue, 08/19/2008 - 00:02
Hi all
How come Cisco ASA cant support VPN's in multi-context mode if you dedicate physical interfaces with different public IP's for each firewall.
I was thinking of integrating our office FW with our new production ASA 5520 and do a virtual a/s setup.
But killing VPN support isnt even an option.
Cisco must fix this imo :)
Farrukh Haroon Tue, 08/19/2008 - 00:25
Yes I totally agree, we must all push Cisco for this. You should start with your account manager.
azore2007 Wed, 08/20/2008 - 03:10
Good news everyone
Talked with our companys account manager and he informed me that VPN support is being worked on and should be released during 2008.
cisco24x7 Wed, 08/20/2008 - 03:54
Let get something clear here:
- Active/Active in ASA will NOT provide load-sharing from the same source. For
example, if you have a host behind
a pair of ASA in Active/Active mode, load-sharing will not be possible by splitting
the traffic from host through both
ASA. ASA in Active/Active mode is like HSRP
with multiple groups.
Others Firewall vendors such as Checkpoint
and/or Nokia have IPSO clustering and ClusterXL that will allow load-sharing through
multiple firewalls from the same source. Checkpoint can do up to 32-node clusters. In other words, you can load-sharing traffics through 32 nodes from the same source, and that you can terminate VPN in Active/Active
mode as well. These features have been
available for almost 5 years now.
kosalasuranjith Mon, 03/08/2010 - 20:19
Dear All,
This was a discussion, we had about a year ago.
But I think still we are not getting the solution. Hope that I m correct.
Still we can t create IPSec VPN tunnels etc in Multi context mode.
We are facing problems, because CISCO has not going to provide this feature.
Can anybody informs, if there are any updates?
