Traffice through two vpn`s.
Aug 18th, 2008
I hope somebody can helping my with this one:
I have make two VPN IPSEC tunnels from different location and terminate it on the ASA 5505. (VPN A and VPN C)
Is it possible to forwarding traffic from location A through the ASA5505 (Location B) and then through Location C.
Location A 192.168.10.0/24
Location B 192.168.125.0/24
Location C 172.30.10.0/24
I want make an connection from 192.168.10.0/24 to 172.30.10.0/24 through the two VPN`s.
Kind Regards
Richard Burts Mon, 08/18/2008 - 07:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Bart
To receive traffic from a VPN (or other source) on an interface and to then send that traffic back out the same interface is sometimes referred to as hairpinning and is what is required to support connection from A to C. By default the ASA does not allow hairpinning. But there are configuration commands that you can use to enable this. Try these commands on your ASA:
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
They should permit the traffic from A to C.
Rick
