CUWL Unity TTS question
Aug 18th, 2008
IGNORE THIS THREAD - I MANAGED TO FIND OUT THAT THE DEFAULT LICENSE FILE WHICH IS INSTALLED DURING INSTALLATION CONTAINS 2 TTS
I used the configuration tool for CUWL. Under unity options it does not list TTS.
Are there any TTS licences included by default with CUWL or do I need to order these separately?
If I need to order TTS seperately, what is the part code?
owillins Fri, 08/22/2008 - 09:58
I think TTS is included with CUWL in Professional Edition, but not Standard Edition. you configure Microsoft Exchange and Cisco Unity Connection so that licensed users can use text to speech (TTS) to listen to Exchange e-mails.
