Phone and Voice Mail
Answered Question
Aug 18th, 2008
I'm drawing a blank here. Where can you change the setting on a phone for the number of rings before a call goes to voicemail? Is that in the phone itself, unity or call manager? Thanks.
Correct Answer by Rob Huffman about 8 years 9 months ago
Hi John,
If you are using Callmanager (later than CCM 4.1) you can change the number of rings before FNA to voicemail using this setting via ccmadmin.
(under>Device>Phone>Directory Number Configuration)
No Answer Ring Duration (seconds)
If you want to change this "system wide" let me know as this can be adjusted as well.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 08/18/2008 - 07:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi John,
Hope this helps!
Rob
