C2821 CPU overload
Aug 18th, 2008
I use a 2821 IOSFW for internet access
It holds 14 DMZ (one Vlan / server on each)
and about 2000 internal internet daily users.
My internet access is 10Mbps symetric.
When trafic grows, CPU grows correspondingly to IP trafic, up to 50%.
I suppose that CPU load is due to IP nat, ACLs and CBAC between inside and outside.
Some external Citrix users sometimes loose their connexion.
Cisco's Commercial argue that I should migrate to ASA 5510, but I need some features like PBR which is unavailable.
I am looking for a serious diagnostic method.
Collin Clark Mon, 08/18/2008 - 09:16
Try checking the CPU load during low volume and high volume times.
show proc cpu | e 0.00% 0.00% 0.00%
I don't think you'll get a definitive answer but it should help point in the right direction.
Also check this-
CBAC was designed for SMBs, not really Enterprises. I understand that routers work better (and I usually suggest them to my customers), but you might have to figure out new routing techniques and put in a ASA firewall.
Hope that helps.
falain Tue, 08/19/2008 - 07:19
I find quite a lot of %FW log msgs
%FW-6-DROP_TCP_PKT: Dropping tcp pkt xxx => yyy due to Invalid Seq# -- ip ident 37313 tcpflags 0x8010 seq.no 2048715884 ack 3899465202
Is it an overload symptom ?
Joined some stat counts in attachment
falain Tue, 08/26/2008 - 07:29
Thanks for reply, but for now due to budget restrictions, I must face the problem without investments.
CPU is mainly due to outbound http traffic.
1) I moved Http PBR from 2821 to inside C3750E vlan switch.
I hope I will gain 10-20% of CPU.
2) Http outbound trafic goes to a squid proxy machine.
If I connect Squid's second Eth Int to another Internet IosFW router (using a free public IP address), may be I can reduce CPU overload of 2821.
I guess Http inspect CBAC is the most CPU consumer.
do you know if there is a better IOSFW release which runs CBAC in hardware as ASAs Asic does ?
For now, I run IosFW 12.4.16 standard train.
Best regards
