08-18-2008 07:32 AM - edited 07-03-2021 04:20 PM
I have a number of 1242AG's installed in a factory, and one of which will not operate properly, as it is on a girder about 20m high, I cannot see which LED, but either the ethernet or radio LED is red, and the status LED is green. This occurs about halfway through the boot process.
Cisco network assistant can see the device, but it cannot be pinged and cannot be telnet-ed to!
HELP!
Thanks.
08-18-2008 10:31 AM
Take a look at this link... hope it helps:
Is this an autonomous AP of LAP?
08-20-2008 11:34 PM
Autonomous AP.
Thanks for the link, I think I will be able to manage now. I could not find that page no matter how much I searched!
Thanks.
08-21-2008 03:27 AM
The matrix was on the link I sent you. You just need to figure out which light is what.
http://cisco.com/en/US/partner/docs/wireless/access_point/1240/quick/guide/ap1240qs.html#wp41161
08-21-2008 11:52 PM
Yeah I got it, just meant the link you sent me was the one i needed but could not find myself!
Thanks again.
08-22-2008 04:36 AM
Ah. Well hopefully you get it working.
08-22-2008 04:40 AM
Should do! Thanks again.
