Contexts on FWSM!!!!!
Aug 18th, 2008
I have the following problem
I am working with security contexts on a FWSM installed on a cat 6500
(I strongly recommend that you take a look at the topology diagram at this point)
My problem is that I can't make server SIRE_APP located on DMZ_SIRE
to communicate with any other host on any other VLAN UNLESS
i manually configure the VLANS I want to communicate with on the CAT 6500
for instance....
In order for server SIRE_APP ( (VLAN 11 --> to communicate with server DNSin ( (VLAN4 -->
i have to manually enter the following lines on the CAT 6500
interface Vlan11
description DMZ_SIRE (configured on context EXTRA)
ip address
no shutdown
interface Vlan4
description DMZ (configured on context EXTRA)
ip address
no shutdown
Then I have to manually change the SIRE_APP server's default gateway to point to
ip (vlan 11) configured on the CAT 6500 instead of pointing
to the ip (configured as an interface on contect EXTRA)
BUT if I do this ALL other hosts on ANY other vlans can't communicate with servers on the DMZ (VLAN4)
NONE of this is (or was necessary) in order for servers on VALN 4
DNSin, OASin to communicate with hosts on any other VLANS
I have setup CAPTURES (raw-data & asp-drop types) but the problem is not an access-list, I have try several NATs but still the same...
I have attached the run config for context EXTRA, context INTRA and context system (CONTEXTS.txt)
and relevan info on the running-config for the CAT 6500 (CAT 6500 with changes)
I'll appreciate any help on this issue
a-ford Mon, 08/18/2008 - 12:52
You don't have a static from DMZ_SIRE to DMZ configured.
Are you getting xlate errors in the log of extra or the admin context?
Try adding a static and pinging.
