Identifying inbound vs. outbound
Aug 18th, 2008
Is there a way to tell if calls on my MGCP gateway are inbound or outbound on my T1 PRI ?
I was running the following commands, and none gave me an indication. I am sure there is a command for this...
sh voice call sum
sh voice call stat
sh call active voice brie
Overall Rating: 3.5 (3 ratings)
mattcalderon Mon, 08/18/2008 - 09:07
I normally just do a quick look at what channels are in use and then verify if telco is sending in top down and we are sending out bottom up.
jbarcena Mon, 08/18/2008 - 09:34
you can also use CCM detailed traces. debugs voice ccapi inout and debug isdn q931
cplatt01 Mon, 08/18/2008 - 10:36
I was hoping to avoid debugs...but you are correct.
