08-18-2008 10:14 AM - edited 03-15-2019 12:41 PM
Hello
I have downloaded the last device pack for CCM6.1.2 (cmterm-devicepack6.1.1.3113-1.cop.sgn) but it doesn't appear on Software Installation/Upgrade files list.
I saw well all files like cm-locale-fr_FR-6.1.1.2100-1.cop.sgn or cmterm-7911_7906-sccp.8-4-1.cop.sgn but no device pack like cmterm-devicepack6.1.1.2110-1.cop.sgn or cmterm-devicepack6.1.1.3113-1.cop.sgn
I don't know why.
Is there a solution ?
Best regards.
08-18-2008 10:50 AM
Ok I have seen that there is a version :
cmterm-devicepack6.1.2.1107-1.cop.sgn
08-19-2008 01:05 AM
I update this conversation because I have got a question :
for ccm 6.1.2, I want to use the last version of device package.
Do I need to use :
cmterm-devicepack6.1.1.3113-1.cop.sgn or cmterm-devicepack6.1.2.1107-1.cop.sgn ?
Thank you in advance.
11-04-2008 12:44 AM
Hi DWAM,
Your question is relevant, I am not sure to have the good answer but I think the device pack main version should be the same of your CUCM version.
If you have a CUCM 6.1.2, install the last device pack 6.1.2.XXXX-X.
I think 6.1.1.XXXX-X is for 6.1.1 only, not for 6.1.2.
Can anybody confirm?
11-04-2008 04:16 AM
that's correct and is totally expected
i cannot use a device pack for 4.1(2) if the one i downloaded says 4.1(3)_devpackXXXX
same for ANY version
java
if this helps, please rate
