Easy log file question for AP 1200
Aug 18th, 2008
I am wanting to troubleshoot the last week's log on a AP, but it only shows 12 hours.
What is the config I need to run to save the logs from the last restart to a file on a server?
Thanks for any info.
bcolvin Mon, 08/18/2008 - 19:14
  • Bronze, 100 points or more
Matt
It is not practical to store that large a log file on the AP due to memory limits. The solution is to configure a syslog server on a PC and then configure the AP to log events on hte server. You can use tftp32.exe for the syslog server function.
Bill
micahcox Tue, 08/19/2008 - 00:05
setup the syslog server with tftp32.exe
enter "logging "
The AP will log to "local7" on the syslog server.
micahcox Tue, 08/19/2008 - 00:08
enter "logging "
enter "logging "
matthogue Tue, 08/19/2008 - 04:37
Thanks for the replies from both of you.
We do have logging facility local0 setup, which I am assuming is just logging on the AP itself.
I will get with the network team to set up a pc as the syslog server and see what happens.
thanks and I'll let you know how it goes.
Matt
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
