How do i put a server in a DMZ zone?
Aug 18th, 2008
Is it just a couple commands to put a server in a DMZ zone? HELP!
Here is what i need....
i have a server which needs to be access from the outside from any ip address.... and in the inside address from on the network only.. Can it be done?
I have an ASA 5520...
Overall Rating: 5 (1 ratings)
Marwan ALshawi Mon, 08/18/2008 - 18:49
lets say the DMZ network is
and the server IP is
do the following
static (DMZ, outside) netmask
if u have a public ip address on the internat and u want users from internet to access that server on the dmz from the internet though that public ip do the following
lets say the public ip is
now u need an ACL on to apply it on the outsid einterface to allow traffic going to DMZ server asuming that the DMZ security level is higher than the ouside
without public IP address
access-list 100 permit ip any host
with public IP
no apply it on the outside interface
access-group 100 in interface outside
now let go to the traffic from inside to DMZ server
static (DMZ, inside) netmask
now the traffic from inside to server will work ok but if u want the server to start the communication with inside network u need ACL to be applied on the DMZ
interface assuming that insidesubnet mask is as follow;
access-list 110 permit ip host
access-group 110 in interface DMZ
and every think wil work
if u need any more details just post here
good luck
please if helpful Rate
accesshollywood2 Mon, 08/18/2008 - 18:55
AWESOME!. i will try when i get to work tommorow... here is one thing....
the cisco webvpn points to the server that has RDP enabled. Basically, once they log into the webvpn, they go to the remote desktop to one of our servers then log in...
would this make any difference?
accesshollywood2 Mon, 08/18/2008 - 18:57
so would i need to use the public IP or the internal IP scheme? since bascially i am using the cisco Webvpn to connect to the server?
accesshollywood2 Tue, 08/19/2008 - 04:48
Everything has been working for a while with this technology. I am on Version 8.0 of the ASA os. Do i still need the RDP plug in? That was the reason we upgraded to 8.0 from 7.2
accesshollywood2 Tue, 08/19/2008 - 06:15
look at the config file that i attached...
the server IP address that i need to put in the DMZ zone is
I wouldnt think it would matter if i was accessing from webvpn. Because once i log in to webvpn it takes us to the RDC page.
