SSL VPN Issues w/ZFW and NAT
Aug 18th, 2008
I'm having two separate issues with my configuration which I would really appreciate some help with. The first being that when using a Zone Based Firewall configuration I'm unable to access my internal network from a SSL VPN Connection. When I remove the Zone's from the interfaces I'm then able to access the internal network. And the second being that I'm unable to access the internet from the SSL VPN Connection weather the ZFW is enabled or not. Attached is my config and any help given would be greatly appreacited.
