CallManager 4.2.3 with multiple Unity Servers
Aug 18th, 2008
We are running CCM 4.2.3 with Unified Messaging 4.2.1 with Exchange 2003. We want to add a second location to the same CallManager, which is running a completely separate Exchange 2003 server. Is it possible to have CCM communicate with 2 completely separate Exchange 2003 servers (different AD domains)?
Thanks in advance.
Rafael COrtes
Chad Stachowicz Tue, 08/19/2008 - 00:07
Well your question is a bit hard to understand to me. If you are asking if you can integrate 2 unity boxes attaches to 2 seperate domains your answer is a a definate yes. If you are asking if you can integrate CCM 4.2.3 to 2 different ad domains for corporate directory, then no.
HTH, please rate useful posts..
Chad
rafael.cortes_2 Tue, 08/19/2008 - 08:19
I am sorry for not being totally clear. I meant having 2 Unity servers attached to 2 different Exchange 2003 servers on 2 separate domains. Is it just a matter of using separate partitions and calling search spaces when creating voice mail ports on CCM? On the Unity server I am guessing you go through the Telephone Integration Manager Tool. Is this the proper way to set this up?
Rafael
Jaime Valencia Tue, 08/19/2008 - 10:24
yes, you can have 2 unity servers attached to the same CCM. just as you mention create a separate integration per server in CUCM
i have 4 unity's attached to a lab server and 4 vm profiles and it's working just fine
java
if this helps, please rate
