Failover Configuration in Cisco Router
Aug 18th, 2008
I have two Servers in different Networks and all the users need to access the server. When one server will be down the user's traffic will be forwarded to another servers. I need this solution in router level and with configuration of Nating. Please find the low level diagram.
Michael.Tuggle@... Tue, 09/15/2009 - 14:41
goutam_04
Did you happen to find a solution to your scenario? I am looking at the same scenario.
mmacdonald70 Tue, 09/15/2009 - 15:09
As mentioned in the previous message, the only IOS feature that will perform this function is Server Load Balancing (SLB). This is only supported in a limited number of platforms and IOS versions (www.cisco.com/go/fn)
iyde Thu, 09/17/2009 - 13:13
Additionally, SLB is in the process of being deprecated from IOS, so the future for laod balancing will be ACE.
HTH.
