AIR-AP1231G-A-K9
Answered Question
Aug 18th, 2008
If client is buying Aironet AIR-AP1231G-A-K9 does it comes with inbuilt/external antenna along wiht the Product or they need to procure the antenna seperately.
Please do clearify the same.
In Cisco Configuration Tool also recomending to buy the antenna separately.
Rama
Overall Rating: 3 (1 ratings)
micahcox Mon, 08/18/2008 - 23:44
The antennas are separate. It comes with the power supply but not a power injector. The 1240's are the current model.
RAMACHANDRA R Tue, 08/19/2008 - 21:02
Can some one suggest, which antenna will be ok in order to get wireless connectivity for near about less than 30 feet from the AP to Wireless client.
Rgds
Rama
