Routing & 3560 switchs.
Aug 19th, 2008
Hi all,
I need a help with routing in 3560's PoE switches. We have circle topology created with 12 switches. Two of them are 3560s. One 24 ports 3560 is default gateway. We need to change default gateway to second 3560 48 ports PoE switch. But when we did it, 48 ports 3560 didnt route traffic from one VLAN to other VLANs and vice versa.
IOS in 48 port 3560 is c3560-advipservicesk9-mz.122-25.SEE1.bin
IOS in 24 port 3560 is c3560-advipservicesk9-mz.122-25.SEB4.bin
Any idea?
jl
massimiliano.se... Tue, 08/19/2008 - 00:13
  • Silver, 250 points or more
Did you enabled routing on the new default gateway with the command:
ip routing?
Massimiliano.
johnleeee Tue, 08/19/2008 - 00:51
Hi Massimiliano,
thanks for help. I think that this was the reason why it didnt route traffic properly.
I will check it and let you know.
BR
jl
