ISDN channel not available
Aug 19th, 2008
Hi Guys,
I am trying to get incoming calls to work.I`m using h323 and only 18 channels.I am getting channel not available tho voice port summary shows my channels are up :
Aug 19 07:57:36: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0001
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2183, '7795806070'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '579260'
Plan:ISDN, Type:Unknown
Aug 19 07:57:36: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8001
Aug 19 07:57:38: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2
0x1, Calling num 7795806070
Aug 19 07:57:38: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0
0x1, Called num 579260
Aug 19 07:57:38: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00FB
Sending Complete
Standard = CCITT
Channel ID i = 0xA9839F
Exclusive, Channel 31
Aug 19 07:57:38: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80
FB
Cause i = 0x82AC - Requested circuit/channel not available
Aug 19 07:57:38: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8001
Aug 19 07:57:39: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0001
Aug 19 07:57:39: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x80
Any thoughts ??
Overall Rating: 5 (1 ratings)
Tim Smith Tue, 08/19/2008 - 04:13
From your debug, your requesting channel 31..
How is your E1 controller configured? Is it configured with timeslots 1 - 31 or 1 - 18?
You can change the order it selects the channels, but that wouldnt be the proper fix.
You want to stop your router selecting channels that arent available :)
Cheers,
Tim
