Access Branch to Branch by VPN
Aug 19th, 2008
Dear All expert,
please help me to solve this problem,
right now my HQ and branch link by VPN but i would like to do 2 branch access by VPN( i mean that now all the branch can access to HQ only but Branch to Branc cannot access .
Could you let me know how can i do it?
Best Regards,
Join
join_sn09 Tue, 08/19/2008 - 02:33
Dear HTH,
Thanks you for your advice.
After i put command that you gave me it mean Branch1 can access Branch2, right? and have more security or not?
Best Regards,
Join
join_sn09 Tue, 08/19/2008 - 18:23
Dear Andrew,
Thanks your for your advice.
i understood that you advice.
Could you show me Acl that allow Branch1 can access to Branch2? so we need to add Acl on ASA HQ, Branch1 and Branch2? which one that we have to add Acl.
Best Regards, :)
Join
join_sn09 Wed, 08/20/2008 - 18:07
Dear All and Andrew,
Do you have any advice?
Best Regards,
Norung
Marwan ALshawi Thu, 08/21/2008 - 03:40
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
Hi Join
first, the solusion that has been given by andrew is 100% the right one
and i just wanna give this link if u read and follow it it let u solove ur case 100% and it is setp by step guid
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807f9a89.shtml
good luck
please, if helpful rate
