PBR on Cat 4500 with Supervisor 6E
Aug 19th, 2008
Hi all,
I'm trying to configure PBR on a Catalyst 4500 with Supervisor 6E running version 12.2(46)SG Enterprise Services.
I'm not able to configure PBR on the interfaces using the command ip policy-map.
Did this feature disappear on this Supervisor???
I've already searched on the Feature Navigator and PBR is not on the list for either license types!
I'm replacing a Sup3 that has that feature configured.
Any help?
paulomv Tue, 08/19/2008 - 02:43
OK, just checked that PBR is not supported on Supervisor 6-E.
Is there any reason for this? Will it be supported in the future?
paulomv Tue, 08/19/2008 - 04:48
The Supervisor 3 is running 12.2(25)EWA8.
I believe that PBR would be working on Sup3 on version 12.2(46)SG. The limitation is really on Supervisor 6-E which does not support PBR.
paulomv Thu, 08/21/2008 - 00:49
Don't worry about that version for Supervior 3 because version 12.2(46)SG is for Sup6-E only.
The latest version for Sup3 is 12.2.25-EWA14 which certainly supports PBR (Must be Enhanced L3 license) because Sup3 supports that feature.
The limitation I've found is in the Hardware not in the Software.
