08-19-2008 03:10 AM - edited 03-15-2019 12:42 PM
Hi I have a CME 4.3 router plus unity Express 3.1 system that is causing me some issues with my config when using COR. when i set the COR restictions on the Dial peers they work correctly and restict the calls to the correct destination - the issue that i am getting is that once the COR is applied it then stops the local phones on the system from calling each other on internal calls - but will allow an outgoing call that matches the COR list ie. to local area call.
Here's my config - any input would be great:
voice user-profile 1
voice translation-rule 8
rule 1 /\(..........\)/ /0\1/
voice translation-rule 9
rule 1 /^999$/ /999/
rule 2 /^9\(.*\)/ /\1/
voice translation-profile filter_add0
translate calling 8
voice-port 0/0/0:15
translation-profile incoming filter_add0
translate called 1
cptone GB
dial-peer cor custom
name internal
name local
name national
name international
dial-peer cor list user-internal
member internal
dial-peer cor list user-national
member internal
member local
member national
dial-peer cor list user-international
member internal
member local
member national
member international
dial-peer cor list call-international
dial-peer cor list user-local
member internal
member local
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-national
member national
dial-peer voice 11 voip
description ** cue voicemail pilot number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 600
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 12 voip
description ** cue auto attendant number **
destination-pattern 601
codec g711ulaw
no vad
dial-peer voice 10 pots
description ** E1 PRI pots dial-peer **
incoming called-number 4.....
direct-inward-dial
port 0/0/0:15
dial-peer voice 5 pots
corlist outgoing call-international
preference 1
destination-pattern T
port 0/0/0:15
forward-digits all
dial-peer voice 3 pots
corlist outgoing call-national
description used for UK wide calls
preference 2
destination-pattern .(1-9)T
port 0/0/0:15
dial-peer voice 4 pots
corlist outgoing call-local
description used for local calls only
preference 3
destination-pattern [1-9].....
port 0/0/0:15
dial-peer voice 1 pots
destination-pattern 999
port 0/0/0:15
forward-digits 3
dial-peer voice 2 pots
destination-pattern 9999
port 0/0/0:15
forward-digits 3
telephony-service
load 7911 SCCP11.8-3-3S
load 7921 cmterm_7920.4.0-03-02
load 7936 cmterm_7936.3-3-15-0
load 7941 P00308000500
load 7942 SCCP42.8-3-3S
load 7961 P00308000500
load ata ATA030203SCCP051201A
max-ephones 240
max-dn 480
ip source-address 10.0.0.1 port 2000
calling-number initiator
service phone videoCapability 1
timeouts interdigit 4
system message CME
url services http:///voiceview/common/login.do
url authentication http:///voiceview/authentication/authenticate.do
network-locale GB
time-zone 21
time-format 24
date-format dd-mm-yy
voicemail 600
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system xxxxx xxxxxx
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
fac custom trnsfvm *
create cnf-files version-stamp 7960 Aug 18 2008 11:25:29
ephone-dn 1 dual-line
number etc xxx
corlist incoming user-international
ephone-dn 2 dual-line
number etc xxx
corlist incoming user-national
System image file is "flash:c3845-spservicesk9-mz.124-15.XZ.bin"
Thanks, Wayne
08-19-2008 04:59 AM
ur config sounds good bu
try to make the following change and let me know
no corlist outgoing call-international
corlist outgoing international
no corlist outgoing call-national
corlist outgoing national
no corlist outgoing call-local
corlist outgoing local
08-19-2008 06:37 AM
Thanks for the quick response. I have tried to make the changes - but as soon as a enter in any of the COR lists on the dial peers it fails to accept the suggested value:
corlist outgoing international = COR list
Regards.
08-19-2008 04:28 PM
u right
i am wonderring about the problem because ur config looks ok !!
09-18-2008 04:45 AM
found the problem my self after going back through the config - some of the users were in a different cor group with the same name applied as outgoing further down in the config - when i had tested the cor it was with these users - so in effect it was 2 differrent cor goups - so the call got blocked. Worked fine one i move all the users to "incoming" on the ephone-dn;s.
