how can I troubleshoot WS-X6416-GBIC card - Pls help
Aug 19th, 2008
Dear Sir,
We have Catalyst 6506 Core Switch with WS-X6416-GBIC card.
On this card 4 nos of Ports got in to the errordisable state suddenly.
So I have made them enable but than also the ports were not communicating. Port shows the physical connectivity but using this port no vtp database flowing.
I have also checked the fiber connectivity and GBIC. No problem in Fiber or GBIC because I have chekced fiber core and GBIC from other ports they r working.
Now what could be the problem ?
How can I troubleshoot it and identify this problem ?
If you requre more detail, I will send u ...........
Pls help !!!!!!!!!!!
Dipesh
singhsaju Tue, 08/19/2008 - 10:54
Try resetting the module and then check.
reset
Saju
Dipesh Patel Tue, 08/19/2008 - 20:18
Dear Sir,
On this all other ports are working fine. Only the 4 Ports have this problem as mentioned.
Is it ok to raised RMA for the same or it can be solved?
satish_zanjurne Tue, 08/19/2008 - 21:57
Attach the config, also show interface output.
If possible attach network diagram.
