ASA5510 Boot problem
Aug 19th, 2008
When i power on the ASA5510, it direct go to the ROMMON. After that i follow the procedure which from http://www.cisco.com/en/US/ts/fn/620/fn62378.html
i able go to the ASA IOS, but when show version it show the image file is from tftp server after that i copy the new ASA IOS into the ASA5510 and set the boot system disk0:asa804-k8.bin write memory on it and reboot the ASA.
However after reboot,it again go to rommon mode. And i issue BOOT command in rommon, it come out the error message as in attachment.
Pls advise urgently.
-Gilbert
massimiliano.se... Tue, 08/19/2008 - 05:08
  • Silver, 250 points or more
I'm in doubt that image is not on flash...is the name of the image correct?
when you issue the command:
show flash:
what do you see?
Massimiliano.
gilbertthor Tue, 08/19/2008 - 05:18
but when i issue DIR in ASA, it got show the file asa803-k8.bin which in disk0:
however i copy another version of ios which is asa804-k8.bin into the ASA5510 and configure the "boot system disk0:asa804-k8.bin
thx
-Gilbert
massimiliano.se... Tue, 08/19/2008 - 05:24
Hi, you issued boot system disk0:asa804-k8.bin but the image present is asa803-k8.bin.
Write boot system disk0:asa803-k8.bin and then reboot, if you can.
Massimiliano.
gilbertthor Tue, 08/19/2008 - 05:26
i had tried it before i copy asa804-k8.bin file into the ASA, but still the same after reboot the firewall it will go to rommon.
-gilbert
massimiliano.se... Tue, 08/19/2008 - 05:30
Ok.
Load image asa804-k8.bin and use boot system disk0:asa804-k8.bin
Let me know.
Massimiliano.
gilbertthor Tue, 08/19/2008 - 05:42
Tried, and the result still the same.
direct go to rommon. In the rommon i type boot disk0:asa804.bin it show out the message which i attach in the 1st reply message.
thanks
-Gilbert
massimiliano.se... Tue, 08/19/2008 - 05:44
ok.
Try to eliminate the istruction boot system with the no command..and then reboot
Massimiliano.
gilbertthor Tue, 08/19/2008 - 05:50
sorry not really get what u means on the next step.
-gilbert
massimiliano.se... Tue, 08/19/2008 - 05:52
Eliminate the boot system instructions:
no boot system disk0:....
and then reboot.
Massimiliano.
gilbertthor Tue, 08/19/2008 - 05:57
hi,
ok i will try it out. but now i can't try on it, will update once i try.
thanks alot for u help
-Gilbert
